Proxy Pass Functionality
Discuss and get help to configure CacheGuard to protect Web servers
fredy.erne@gmx.ch
Post by fredy.erne@gmx.ch »
I'm looking for some Kind of proxy_pass configuration, as example I have only one external URL, but do have multiple subsites. I like to "Forward" those subsites to different internal URLs:
http://www.example.com -> server1.internal.com
http://www.example.com/test1 -> server2.internal.com/test1
http://www.example.com/test2 -> server3.internal.com/test1
is there any way doing this with cahcheguard?
Thanks and Regards
Fredy
Re: Proxy Pass Functionality
Dear Fredy
CacheGuard does not support the configuration you requested because such a configuration requires that Web applications be written in respect of some constraints (usage of relative links for instance).
Please keep in mind that CG is a generic reverse proxy with some constraints that help avoiding complex issues while remaining compatible with all Web application servers and specific applications.
I suggest that you use the following configuration instead (if possible):
http://test1.example.com -> <ip-address-1>
http://test2.example.com -> <ip-address-2>
http://test3.example.com -> <ip-address-3>
Where <ip-address-?> could be real or virtual IP addresses on the backend Web servers. Then you can use virtual hosts on backend Web servers to get the required configuration.
