Hyperv 2012R2
Discuss and get help to install CacheGuard-OS
dujonn
Hyperv 2012R2
Post by dujonn »
Hi, I have an issue in that when I try to install CacheGuard on a HyperV 2012R2 VM the NIC's I add are not detected.
Does CacheGuard support Hyperv 2012R2?
Re: Hyperv 2012R2
Thank you for your post and sorry for the delay in our response.
Actually we have never installed CG in a HyperV 2012R2 VM but it should work in theory as CG has been validated with previous HyperV versions.
Also CG v1.2.2 is based on a Linux kernel 3.10.100 and according to my information that kernel works well on a HyperV 2012R2 VM. If the only issue you encounter is the detection of your NIC try to attach another type of emulated network adapter to your VM and try to reinstall CG.
Please let me know what is the emulated network adapter that CG can't detect.
quarinteen
Re: Hyperv 2012R2
Post by quarinteen »
Did you find a solution for this? I am having the same problem
Re: Hyperv 2012R2
Can you please let me know what type of network adapter do you use in your Hype-V VM? And what are other possible network adapter types?
