I'm faced with Error 1004 "Atleast two Network Interface Cards are required"
I am using a Toshiba Satellite U845W S400 laptop with built-in ethernet and 90-XB3900CA00040- ASUS USB 2.0 to Ethernet Adapter (https://www.asus.com/Notebooks-Accessor ... /overview/).
Where am I going wrong?
Error 1004
Re: Error 1004
Dear Mudit
I'm afraid that one of your NICs or both are not detected because its driver is (are) missing in CG-OS. After the hardware detection step and the Error 1004 displaying you should normally get the list of detected hardware. To allow us to know which driver is missing please send us the list of detected NICs. You can also return to the main installation menu and select "Hardware" to get that list.
