Hi Folks,
Unfortunately I’m experiencing problems with CacheGuard in rweb mode. When I’m accessing our HTTP Webserver through the CacheGuard Appliance from our internal network, it’s working fine. But when I’m trying to access via Internet (Internet > Firewall > CacheGuard > Webserver) I get “Error 1007 – forwarding not available”.
In the Firewall I’ve forwarded port 80 to the CacheGuard Appliance. There is no packet drop in the firewall. Wireshark says that the CacheGuard Appliance returns Error 500 to the client. I can see the Error 500 only in Wireshark.
(I’ve also tried it with SSL offloading. In this Case the SSL handshake works fine, but after the successful encryption I get the Error 1007 page)
This is, when I’m using no waf. When I activate waf, I get the error “no access right to the directory”.
Thank you in advance!
						Forwarding Error 1007
Re: Forwarding Error 1007
Thank you for your post.
The error 1007 means that CG is unable to properly reach backend web servers. Not because there is a TCP connectivity issue (Error 1009) but because backend web servers can't properly handle requests coming from CG. Quite frequently, this is due to virtual hosts misconfiguration on backend Web server.
Can you please have a look on your Web server configuration and verify that all virtual hosts are properly defined? I would also be interested in getting the output of the following commands:
rweb site
rweb host-
				GEROholding
I've already found the problem. It was a misconfiguration in the A-Record of my Domain. CacheGuard didn't know the specified domain in the A-Record, in other words the http request contained a wrong domain, and so CG blocked access from outsite the external network (internet).
It's my first try with a reverse proxy. But I really appreciate CacheGuard. It's simple and easy to use.
Thank you very much.
Oh I see. I think that you talk about an A record in your local DNS server which should associate the name to CG's external IP address (a private IP address). In any case, I'm happy to hear that you resolved the issue.
