https on custom port
Discuss and get help to configure CacheGuard to protect Web servers
tdurham
Post by tdurham »
Using rweb (reverse proxy) to access some cPanel and Virtualmin resources (servers admin panels) I'm having trouble setting up https to occur over a non-standard SSL port (other than 443).
Example: https://web2.example.com:2087 or https:web1.example.com:10000
Is there a processes to get this handled in the CacheGuard Reverse Web Configuration?
Your assistance is greatly appreciated.
Re: https on custom port
Hi tdurham
With the current version (v1.1.5) it's not possible. CacheGuard uses standard ports (80,443) for cloaked Web servers and can act as a SSL terminator (if needed). Some reasons for that limitation are:
- Keep a CacheGuard configuration as simple as possible.
- Minimise the number of opened ports.
I suggest you to either:
- PAT your specific ports (2087, 10000...) to CacheGuard's IP:443 on your frontal router/firewall
OR
Use specific names for each service (service1.example.com:443, service2.example.com:443...). FYI the current version (v1.1.5) supports the SNI (Server Name Indication) extension of TLS so you can use the same IP address for different HTTPS names.
