Configuration Breaks System
Discuss and get help to configure and maintain CacheGuard
FortifyIT
Post by FortifyIT »
Just trying to configure a new install of CG 1.3.7. I'm going to set it up as a true proxy server in a colo for my clients. trying to enable the features, click apply and it starts saving and then it fails and then look on the console screen and it says over and over again: INIT: cannot fork, retry...
I can't do anything after that. Even if you kill the system, it just starts doing that same cannot fork junk after it gets halfway done with boot up.
FortifyIT
Re: Configuration Breaks System
Post by FortifyIT »
I'll reinstall and get the options that i am trying to turn on and post them
FortifyIT
Post by FortifyIT »
Oh forgot this, the error at the beginning says something about the /usr/apl something along those lines, i'll take pics next time it happens. and is says "Cannot allocate memory"
FortifyIT
Post by FortifyIT »
i think it was the anonymous browsing that caused things to break
Thank you for your feedback. We look forward to having a screenshot of the error if it occurs again.
All the Best,
FortifyIT
Post by FortifyIT »
I hope it doesn't happen again. haha.
I will let you know. I got the server setup at my Colo and it's running. I'm going to test it. I did the two public IP addresses. Set my Proxy settings and I'm browsing around so I think i am good for right now.
I will do some testing and let you know if I need anything
Mike
