CG Appliance shutdown / reboot
Discuss and get help to configure and maintain CacheGuard
As VMware Tools are not permitted in the CG appliance, so no “Shut Down Guest” option exists, can the appliance just be "Powered off" or is there a better way?
Re: CG Appliance shutdown / reboot
To reboot/shutdown the appliance you can use the commands reboot and halt from the CLI or the menu option [GENERAL] > [System Operations] > [Reboot | Halt | HA State] from the Web GUI.
Actually CG uses journalized filesystems and is by design fault tolerant against sudden stop so in theory a power unplug should not really hurt. However there may be unknown cases where a sudden stop of CG can hurt the consistency of its configuration. That's why it's always safer to use the commands above.
