nic configuration issue
Posted: 22 Jun 2017 04:52
I am trying to configure CacheGuard and running into problems while applying the settings.
I have a single network 192.168.50.0. The gateway 50.1 was terminated at firewall. Please advise how should I configure the two NICs? When I assign two IPs of same network for internal and external, it returns below errors..
*** Error 203 - The appliance IP addresses cannot belong to overlapped networks.
*** Error 206 - Gateways in the routing table should be connected to the appliance.
*** Error 200 - Integrity error.
For testing purposes, I have created a VLAN and configured one from each networks. Now error 203 is gone but the remaining two errors still there.
The reason for evaluating CacheGuard is to check the functionality of webproxy feature whether it can restrict the access to consumer google accounts while allowing access to specified domain hosted on google (google apps). In other words, work email hosted on google should work and personal gmail should be blocked. If this can be achieved, we can work further on licensing part.
Sreenivas
Sreenivas
