Internal: error 78 when transferring the files
Discuss and get help to configure the URL filtering
I'm using this command
guard category load create WebMail ftp 192.168.110.4 WebMail domains urls
I've set also the password for my FTP user, and I've tested it with a ftp client.
password ftp add 192.168.110.4 user@mydomain.com
In the root of the FTP server I can see two files:
WebMail.domains
WebMail.urls
I have also downloaded those with my FTP client with no issues. This probes that the server is serving the files correctly.
The message I receive from CG after the "guard load create..." command is:
Internal: error 78 - The resource referenced in the URL does not exist.
Any ideas?
Re: Internal: error 78 when transferring the files
I recompressed the files, and after that is working.
The error is not showing anymore.
I'm happy to hear that. Actually with the command "guard" when you specify a file name, the system adds some extensions to it as follows (extract of the documentation):
The <base-file-name> parameter is the base file name (without extensions .domains.gz , .urls.gz or .expressions.gz ) of a user defined category. File(s) must exist and be accessible on the file server. The optional last arguments specify which category types to load. Category types are : domains , urls and expressions If no category types are specified, domains and urls category types are loaded.
