Internal: error 78 when transferring the files
Posted: 19 Sep 2015 17:13
by miguelp
I'm using this command
guard category load create WebMail ftp 192.168.110.4 WebMail domains urls
I've set also the password for my FTP user, and I've tested it with a ftp client.
password ftp add 192.168.110.4 user@mydomain.com
In the root of the FTP server I can see two files:
WebMail.domains
WebMail.urls
I have also downloaded those with my FTP client with no issues. This probes that the server is serving the files correctly.
The message I receive from CG after the "guard load create..." command is:
Internal: error 78 - The resource referenced in the URL does not exist.
Any ideas?
Re: Internal: error 78 when transferring the files
Posted: 19 Sep 2015 19:11
by miguelp
I recompressed the files, and after that is working.
The error is not showing anymore.
Posted: 19 Sep 2015 19:35
I'm happy to hear that. Actually with the command "guard" when you specify a file name, the system adds some extensions to it as follows (extract of the documentation):
The <base-file-name> parameter is the base file name (without extensions .domains.gz , .urls.gz or .expressions.gz ) of a user defined category. File(s) must exist and be accessible on the file server. The optional last arguments specify which category types to load. Category types are : domains , urls and expressions If no category types are specified, domains and urls category types are loaded.
